Visits: 1.4K
I found a higher ratio rear end for my '56 Victoria from one of the members here on y-blocks forever. Doing some research to find out what my current ratio is (V-8 automatic as originally purchased) there was a statement made on another website that the '56 exclusively had fine spline for their axle shafts. I have never heard such a thing before. I made a call to a knowledgeable friend and he said that statement is "hogwash".
OK, guys. I know you know the answer. Does the '56 have different splines on their axles?
Visits: 20.6K
Early 55s had course splines and i think some later 55s had the fine splines the 56 axles were fine .Jack i will count the splines on both for you in the next couple days,also will check the 4.11 splines Carl
Last Active: 7 hours ago
Visits: 323.0K
'49 to early '55 had 17 splines, late '55 and '56 had 28 splines.
Visits: 20.6K
John is correct Carl
Visits: 2.9K
positive here in oz we had 2 types
Posts: 3.6K,
Visits: 497.7K
A 56 with an automatic usually had a 3.31 rear ratio. Check the shop manual.
Visits: 20.6K
1956 cars with auto trans had 3.22 gears,56 police interceptor cars with auto trans had 3.31 gears recheck your manual Paul Carl
