Visits: 3.5K
If you are still looking a rear end...3.89 or 4.11 overdrive units, call VANPET SALES in Balavia, Ohio (near Cincinnati) PH 513.724.9488. They have all kinds of parts for trannys and rear ends. Good Luck, Tim Hot 'n Humid, FL 33706
Visits: 10.6K
Jack I have a Dana rear out of a low millage 1956 Mercury with O.D. that I drove and it worked as it should teeth count is 45/11 =4.09 ratio $175.00 Call Harry Hutten Jr. 513-868-3311 located in S W Ohio
Visits: 2.4K
The pre 1957 Ford pickups also used the Dana 44 axle.
Last Active: 5 days ago
Visits: 20.7K
hjh (7/22/2020)
Jack I have a Dana rear out of a low millage 1956 Mercury with O.D. that I drove and it worked as it should teeth count is 45/11 =4.09 ratio $175.00 Call Harry Hutten Jr. 513-868-3311 located in S W Ohio The shock brackets are different on the Mercury rear end and also wheels are different bolt pattern Carl
Visits: 1.4K
I'm going to close this whole subject out. I got the car running and took it out for a drive for the first time since I swapped the transmission to a Mustang 5 speed w/overdrive. The engine turns 2700 rpm at 70 mph which is just about perfect. Apparently I have a 3.55 rear end. Thought I had a 3.31. So no need for a different rear end. Thanks for all the replies.
