Push Rods
Posted By 1946international 6 Years Ago
Posted 6 Years Ago
See if this link to John Mummert’s site helps.
http://www.ford-y-block.com/rockerarm.htm
1946international
Posted 6 Years Ago
Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)
Posts: 107, Visits: 21.5K
PART#         ROCKER ARM RATIO                  VALVE DIAMETER                    PUSH ROD LENGTH (Effective)
EAN                54-55 jamb nut     1.43:1                EXHAUST all 1.51"                1954-55 3/16" radius ball 8.11"
ECG 6564     56 jamb nut            1.54:1                INTAKE 1954 1.64"              1956-59  3/16" radius ball 7.98"
ECG 6564    57 self locking      1.54:1                 INTAKE 1955-56 1.78"        1960-64  3/16" radius ball 8.11"
5751066      58-64 self locking 1.43:1                INTAKE 1957-59 1.93"
        INTAKE 1960-64 1.64"
as always, thanks Ted.
the above is clipped from that site, so it looks like the rocker style (with or without the self locking feature) makes the difference, weather you use the longer or shorter push rod. Assuming all the valves are the same length, as the exhaust valves are all the 1.51" and this does not recommend different push rods for intake or exhaust I guess this would be the case. So according to this, it looks like I would use the longer ones.
