Ford O Matic dipstick tube
Posted By MoonShadow 17 Years Ago
Posted 17 Years Ago
Posts: 4.6K, Visits: 38.1K
Anybody got a decent dipstick tube for a Ford O Matic. Mine is broken off. Chuck in NH
Glen Henderson
Posted 17 Years Ago
Posts: 1.4K, Visits: 7.5K
Chuck, let me dig through my stash this weekend, I might have one that not broken or bent up. I'll let you know if no one else comes through.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posted 17 Years Ago
Last Active: 1 hour ago
Posts: 3.7K, Visits: 322.6K
Chuck:
I don't think the FOM tube will fit your newly installed AOD.
John
Posted 17 Years Ago
John, Aod is being a stubborn pig! I had the pressure set but they couldn't make it shift to 3d. I fiddled with the TV cable and got 3d and overdriver but it seemed to freewheel a lot and the shifts weren't quite right. THEN, after a short test drive the 600 carb started flooding. Since I had rebuilt a 450 Holley I put it on. Same sort of flooding problem. May have been related to the 9lbs of non adjustable fuel pressure but? So I took my old 600 vacume secondary off the shelf and put it on. Runs fine now?? Problem, while changing carbs the TV linkage changed detent. Now I run in 1st gear only with no up shift just freewheels when I let off. Tried adjusting the TV cable but no luck yet. I picked up a pressure gauge and am going to check that out. If it ever stops raining!
If that dosen't work, the old FOM is going back in. I have everything for it except the tube is trashed. I used an old 57 Ford shaft to have the new one made to I have the old driveshaft and all. I may have to rig up the shift linkage but I think the Lokar kit will do it. It's kind of sad. I really liked the way the old girl took off with the AOD seems pretty strong for a change. I'm sure the new motor will be better with the FOM but I had high hopes!
 Thanks, Chuck in NH
carl
Posted 17 Years Ago
Posts: 1.2K, Visits: 20.6K
chuck     i have a decent one,i am going to bring 55 56 parts to sell at national trails labor day week end.if you need it sooner i can ship it to you .   Carl  Ohio
carl
Posted 17 Years Ago
Chuck I shipped the tube and dipstick today,should get to you at the end of the week  Carl
Posted 17 Years Ago
Thanks Carl. I'll be watching for it. See you in Columbus.. Chuck in NH
