292 stock Intake manifold
Posted By C.E. Carroll 5 Years Ago
C.E. Carroll
Posted 5 Years Ago
Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)
Posts: 3, Visits: 8
I am rebuilding my 1959 Ford truck 292 and down to the carburetor.  Looking at the 2bbl and the plenum inlets of the intake, it looks to me like there would not be a good fuel/air passage.  The intake plenum is larger and I would think a designed spacer with tapered ports should be used.  Maybe I am over thinking this but in my past life nozzles did not have sharp turns and flat surfaces to obstruct the gas passage.  A diverging gas passage would seem to be correct.
Posted 5 Years Ago
Maybe others on here will have a better feel for what you are trying to get at, but the Plenum is "larger" than what?  If you are comparing that intake to other V-8s (?) keep in mind the ports are stacked, not side by side as in other V-8s. And the fuel mixture is mixed in the carbs venturies, there is no "nozzle" as in fuel injection. Granted the intake is a somewhat crude casting, but it probably works well for use in a truck engine, where you want good torque at lower RPMs.  Also, the top design of a Y-Block has more even length intake runners than other side by side V-8s...
Posted 5 Years Ago
Last Active: 6 hours ago
 I’m guessing that on the spacer that you have in mind would be a reverse taper where the top inlet holes match the carburetor while the lower hole dimension matches the inlet hole size in the intake.  If that’s the case, then it’s a ‘Yes’ in that you could do that.   The amount of benefit if any with a small 2 barrel carb would be subtle.  There are those instances where having a ledge in the intake flow is actually beneficial as it further helps to atomize the air/fuel mixture and especially in the low rpm band.  This sounds like something that should be dyno tested to confirm if it’s worth the trouble in doing.
FORD DEARBORN
Posted 5 Years Ago
Posts: 785, Visits: 113.4K
I'll try to post a couple pics of how I accomplished what Ted described above.  In my case, it's a Holley 600cfm that has a larger throttle bore than the standard iron 4 barrel manifold. Being a truck, hood clearance wasn't an issue. The 1" aluminum spacer purchased from NPD matches the port size of the carburetor. The plastic composition spacer is a standard 1/2" 57 ford spacer I modified by tapering the holes at the top to transition larger matching the carburetor bore size. My thinking was to provide a smooth flow down the chute for whatever that may have been worth. It was relatively easy to do with off-the-shelf parts. Hope this helps, JEFF.........http://forums.y-blocksforever.com/uploads/images/29a408b1-e9cb-4fd2-a1c9-449a.jpghttp://forums.y-blocksforever.com/uploads/images/ca7d8497-1740-4fda-8168-6824.jpg
