Rowen
Visits: 29.3K
I havent posted here for a while so, hello again fellas. Has anyone here installed an oil cooler? I can little into on this. I installed one for my 304 stroker and lost near half my oil pressure. Went from 60lbs cold to 40 and 45 warm to 20 and dropped as low as 15. Any experts with ideas how to handle this? I can give more specifics on the install if needed. Thanks in advance.
Rowen 55CV Woodland, Ca
Last Active: 6 hours ago
Posts: 7.5K,
Visits: 205.8K
Line size in and out of the engine oil coolers is important. The cooler construction is also a key player in that it needs be designed for engine oil and not be a transmission cooler being retrofitted for engine oil cooling use. In theory you can get away with AN10 sized lines but I prefer AN12 for any external oil coolers or remote mounted oil filters. If the total length away from the engine gets excessive, then additional oil flow may be required like a high volume oil pump. Treat fluid flow just like you would when wiring with electricity.
Rowen
Visits: 29.3K
Ted, thanks so much for the reply!! So here are some specifics on my install. The lines are 3/8" ID. Approx 7' total length. Remote filter near the top of the core support. Oil cooler on top of inner fender driver side using fresh air horn for cool outside air. Do you think going up to a 1/2ID line and getting the filter and cooler lower will fix the issue?
May not mean anything but what brand of oil do you use? I ask because of experience with one brand and low oil pressure with no other explanation.
Rowen
Visits: 29.3K
My engine builder, John Beck said to use straight 30wt. That's what I've been using since new and no issues till I installed the cooler.
Joe-JDC
Last Active: 1 hour ago
Visits: 22.4K
I am curious as to why you need an oil cooler? If the engine operating temperature is maintained with thermostat, then the need for an oil cooler is nil unless this is a tow vehicle that will be loaded for long periods of time. Cool oil robs horsepower. Joe-JDC
Rowen.... say hi to John for me the next time you see him... just say JD and he’ll start laughing. I’ve been friends with John and Dave Davidson for 25 years.... PS: oil brand referred to is Pennziol. I’m just one of many who went to zero at idle after 30-40 psi with other brands.
mark9088
Visits: 8.2K
on my supercharged Y I have the block water jackets filled over 1/2 way up the water pump holes for cylinder strength and rigidity for hi boost capability. While drag strip usage would probably not present a oil temp problem street/hiway driving could definitely be a problem. I am attempting to retrofit the oil cooler/heat exchanger Ford used on the early 90's 5 liter mustang police specials to my y block. it basicly routes coolant from the bottom of the radiator pulled thru the cooler by the water pump..thus not effecting oil system at all. testing has been interupted do to health issues..
Posts: 7.5K,
Visits: 205.8K
Rowen (4/22/2020) Ted, thanks so much for the reply!! So here are some specifics on my install. The lines are 3/8" ID. Approx 7' total length. Remote filter near the top of the core support. Oil cooler on top of inner fender driver side using fresh air horn for cool outside air. Do you think going up to a 1/2ID line and getting the filter and cooler lower will fix the issue?The 3/8” I.D. on your current lines is the equivalent of #6AN. While that is suitable for gasoline, it’s too small for engine oil and especially with a seven foot length to contend with. As the lines get longer, hose sizes must increase accordingly. In looking at the pictures you provided, the fittings look to be additional restriction points. While those fittings work okay for forklift hydraulic lines, they are unsuitable for what you are attempting to do. As I mentioned earlier, #10AN (5/8”) would be the bare minimum and I always opt for using #12AN (3/4” I.D.) for any engine oil lines whether they are for a remote cooler, remote oil filter, or a dry sump oiling system.
