Tires/rims
Posted By MplsMike 6 Years Ago
MplsMike
Posted 6 Years Ago
Last Active: 7 Months Ago
Posts: 204, Visits: 92.3K
Hi all,
I know this subject has been discussed many times, but I am having trouble searching for related posts. I have a 1956 Parklane wagon and it is time for new rims and tires. What is the standard size rim for this car including backspacing?
MplsMike
'56 Parklane
Minneapolis, MN
Posted 6 Years Ago
Posts: 1.2K, Visits: 285.6K
I don't know.  However, I recently had an experience that you may find useful.  My 55 TBird still had it's original 15" steel wheels and stock hub caps when I purchased it.  I could not find any concrete information on what if any after market wheels and tires would fit.  I was told every car is different and that I should measure to be sure.  I had previously installed radial tires on my car.  The radial tires on the stock steel wheels vibrated throughout the car at 50 miles an hour and over.  I put up with it in the beginning.   Wanting to improve the looks of the car and the drivability, I started my search for new wheels.
Luckily, I had a friend with a 55 Ford that had after market wheels.  He had 5" Rocket Wheels on the front and 7" wheels on the back.  I decided on 6" wide by 15" diameter Rocket Ignitor Wheels with 215/70R Radial TA tires.  I bought them from CARID.com.  They guaranteed these wheels would fit and they did.
I couldn't be happier with my new wheels and tires. The vibration is totally gone.  My new wheels have neutral backspacing which brought the wheels and tires out about an inch improving the look and stance.   All cars are different.  If you have aftermarket brakes, tires or anything, be careful before you buy.  My wheel box clearly stated "If you mount these wheels, you bought them."
blocky
Posted 6 Years Ago
Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)
Posts: 129, Visits: 2.9K
i recently replaced my oriinal steel rims with new 15 inch by 6 inch CT&W  steels and the standard cap also fits i believe these wheels originate in your part of the world,made in USA .tyres are 205/70x15 hope this is of some use to you.
MplsMike
Posted 6 Years Ago
Thanks for the replies, guys. I am thinking 6 inch wide rims with 235/75/15 tires in the back, maybe a little smaller (215) on the front. I would like a wheel that accepts the dog dish style hubcap. I’m not sure what backspacing to order.
Too wide for the back?
MplsMike
'56 Parklane
Minneapolis, MN
Posted 6 Years Ago
Posts: 3.7K, Visits: 498.2K
On my 54 Victoria, I went with Cragar S/S, 14 X 6 i the front, 15 X 7 in the rear.  What they call standard offset.  215 70's in the rear, room is tight  for removal.  195  75's in the front. Granada disc's in the front, bigger drum brakes in the rear. Really like the look of the S/S's
http://forums.y-blocksforever.com/uploads/images/cb5b5324-411f-49ac-a665-a0b2.jpg.
Posted 6 Years Ago
Last Active: 4 days ago
Posts: 1.9K, Visits: 195.0K
Mike, I think the oem wheels where 5", and 3" backspace. Long time since I measured them and I wouldn't trust my memory completely.
My bird runs 15x7 front, 3 1/2 inch backspacing. 225/60 15 T/A's. Some guys say you can go 4" on the front, but mine are as close as I'd go from the sidewall to the upper ball joint. 4" wouldn't clear on my car.
The rears are 15x7 4" backspace with 235/60 15 T/A's. No skirts, and very tight to the outer fender lip.
I wouldn't have gone to those sizes, but the local tire shop did the measurements and guaranteed they'd fit. It was damn close, on a left hand turn the left rear would shave rubber. The body was 1/4" off the center of the axle, and relocating the body just solved the problem.
If I were doing it over, I'd be 15x6, 3 1/2" backspace, and no more than a 225, probably a 215. Aspect of 70 or 75. The 60's work for me because the car is lowered and they fill the wheel openings.
I know this doesn't help a lot with a Parklane, but the front suspension is the same. Some have reported with larger wheels and tires they need to drop the rear shocks off to change a tire.
Years ago Wheelsmith made me a set of 15x7" rims on factory 55 centers. They used the factory dog dish, and put 10" cheater slicks under the back of the bird. Looked great sitting, driving on those not so good. They might be worth a phone call.
https://thewheelsmith.net/
Lou
Posted 6 Years Ago
Last Active: 4 Months Ago
Posts: 564, Visits: 8.4K
Keep your old steel factory wheels and hubcaps, you never know what the next fad will be.
Posted 6 Years Ago
I believe most of us set up our cars depending upon the era we want our car to be in.  Full hub caps for the fifties.  Baby moons and Cragars in the sixties.  Torque Thrust Ds in the seventies, Etc.   A Thunderbird with wire wheels to me looks like it's sitting in a country club parking lot.  The same car with Salt Flat Specials looks like a racer.  Dog dish hub caps are universal.  Many 60s muscle cars came that way from the factory.  I special ordered a 429 Cobra Jet Torino Brougham in 1971. I remember picking it up at the dealership.  It came with dog dish hub caps.  The sounds coming out of that car were awesome.  It would blow the doors off most scrubelles with the air conditioning on.
I don't know if anyone makes a new steel wheel that will mount your dog dish hub caps. Let us know if you find them.
MplsMike
Posted 6 Years Ago
Thanks for all of the tips. I will check out wheelsmith; I am also going to check out wheel vintiques - I like the idea of talking through this with a real human at one of these places.
MplsMike
'56 Parklane
Minneapolis, MN
Posted 6 Years Ago
These postings touch on  clearance issues at the rear with non std wheels & tire sizes. Some of the trouble is due to Shocks that are not long enough.. Apparently, some shock listings for mid 50s Fords are "fudging" their fit. On my 57 car, I had to insert extra washers on the shock ends to ensure clearance for a tire change & my car has std wheels & 205 x 75s..
