OIl Breather Cap
Posted By customline3859 6 Years Ago
Posted 6 Years Ago
Last Active: 5 hours ago
Posts: 4.6K, Visits: 39.3K
Being an open faced filter I'm assuming at speed it could cause air to be forced into the crankcase. Other than that I just liked it better than the one without it. The shield only blocks the front of the filter the rest is open. I am also running a PCV valve and no lower crankcase breather.
Posted 6 Years Ago
I asked & you answered, thanks.. actually I'm running somewhat the same setup, only my intake oil cap is a std large filtered Autolite cap & also with a PCV setup. It has been suggested here that the filtering of that cap may be marginal, but I don't  drive the car in bad conditions (dust etc). So, I'm going with it as is.. So far it seems to be working well.
N.B.- late correction;  I described the above cap as being an Autolite..the labels off it, but I believe that should have read "Motorcraft".
