Ethanol issues..
Posted By PF Arcand 5 Years Ago
Posted 5 Years Ago
Lot of complaints on this site & others I'm sure, about the damage that can come from ethanol laced fuel.. Some have chosen to use premium fuel as it usually has little or no ethanol. Unfortunately, premium fuel is quite a lot more costly.. Anyway, another route to consider is the use of a Fuel stabilizers such as under the company name Staybill, (there may be others also)  which is available with an ethanol "stabilizer" under the name Staybill "360". Adding about 1 oz/ 5 Gal. of fuel is supposed to alleviate the ethanol issues.. Note; that company may have changed the branding on that particular product, so ask if you can't find it..
Posted 5 Years Ago
Posts: 1.2K, Visits: 285.6K
I drive my TBird frequently.  I use nothing but high test gas.  I also have a new carburetor and a new gas tank.  My original carburetor is in a box under my bench.  I work with a friend that has a large car collection. Most of the problems we have with gas are due to non use.  If you drive your car often and keep it properly maintained, you won't have problems with fuel.
Posted 5 Years Ago
Last Active: 6 hours ago
Posts: 1.8K, Visits: 306.3K
https://www.bellperformance.com/blog/the-disadvantages-of-adding-ethanol-to-your-fuel
It is very caustic mixture, especially in older vehicles that were not designed to use it.
If you have an open vented fuel tank (no EVAP), it will cause problem(s) at some point, even with the use of stabilizers.
Posted 5 Years Ago
I've used Sta-bil with every fill up for 8 years. I first started with the original formula then moved to 360. I have looked in my tank many times messing with my gas gauge sender and it's spotless. I put in 1 oz. with every fill up usually around 10 gallons. For the most part I use 87 octane and occasionally 89.
Taxiforina gasolines all have ethanol near me and I have never had a problem with the exception if it sits over a month when it needs about 10 seconds of cranking before I pump once to set the choke on the rear carb. The only rubber/flex line in my system is from the main feed line to the pump which was a replacement 5/16" for a 57 Scrubby from Danchuk. You will never convince me not to use an additive as I consider it preventive maintenance.
tomfiii
Posted 5 Years Ago
Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)
Posts: 52, Visits: 122.7K
Throw out all old rubber fuel lines as they deteriorated from fuels today. Use alcohol fuel approved or marine fuel lines. I have found lines deteriorated in less then 3 yrs.
Posted 5 Years Ago
Posts: 3.6K, Visits: 497.7K
I have used 10 % in all my cars for years.  Never used any stuff like Sta-Bil at all.  Never had problems with the fuel systems.  The only thing that I do is about once a month when the cars are off the road is to start them (take for a ride if possible) and get them up to running temp.
Son used Sta-Bil one year in his 302 powered 41.  Gummed up the carb something terrible
Joe-JDC
Posted 5 Years Ago
Last Active: 1 hour ago
Posts: 772, Visits: 22.4K
I used Stabil in one vehicle that wasn't driven much because of wanting to keep mileage low.  Ruined the fuel tank, fuel pump, fuel lines, and had to replace them.  Vehicle only had 23000 miles on it.  Stabil caused the fuel in the tank to turn to something looking like foam rubber.  Never again!!    Joe-JDC
ghancock
Posted 5 Years Ago
Posts: 4, Visits: 41
Something that might be mentioned, if not previously said, is that ethanol fuels tend to develop something like an enzyme based scum in the fuel that causes problems. I am back to the hobby after many years away. In any event, there is a fuel treatment product by "Star-Tron" that supposedly addresses this problem, I have read about it some in the past, you might look it up; perhaps Sta-Bil does the same thing. It may be worth a look.
slumlord444
Posted 5 Years Ago
Posts: 1.2K, Visits: 137.8K
I've used Stabl in my T Bird, lawn mowers, and antique John Deer tractor for many years. Never had an issue that I can blame on it.
Posted 5 Years Ago
I'm taken aback by Joe's apparent fuel system disaster!. It's well known that Ethanol can raise hell with older systems not designed for it.. However, if Stabil "360", particularly formulated for Ethanol, is also a problem, why is it still marketed? . The recommended dose for 5 U.S. Gal, or 660 oz, is about one ounce.. that work's out to about .15 percent.. Gotta be something else happening there.. First, regular Staybil was "not rated" for Ethanol fuels & it's normal dosage was supposed to be for 12 months or doubled for storage for up to 2 yrs & it was recommended to run the engine long enough to circulate it thru the carb etc.. Beyond that, I presume the tank & so on should be drained...
