Visits: 137.8K
How do I tell if a crank is a forged 292 out of a truck? Have one that is supposed to be one but not sure how to ID it. Also any idea of what a turnable one is worth? I have someone localy looking for one and no idea what one is worth.
Visits: 442.8K
The forged crank has no counterweights in the center. You can also id it with the number or flange. http://www.ford-y-block.com/crankshaftid.htm
Visits: 22.4K
A cast crankshaft will have a very thin straight casting lines where it came out of the molds, whereas the forged crankshaft will have a very thick uneven line where the forging metal bulged at the parting lines from the forging process. Joe-JDC
Visits: 137.8K
Thanks, That helps a lot. Any idea what the going rate for one is? Not looking to get rich off it. Just looking for a fair asking price.
Visits: 4.5K
which of them is the most desirable? Can you tell me by the image what is this? thanks and sorry for the intrusion
Last Active: 37 minutes ago
Visits: 323.0K
Yours is a cast crank. For your use, it is completely adequate.
Visits: 22.4K
Do you see the crankshaft throw just in front of the #2 Main? There is a thin parting line in the picture visible. Like John said, it is a cast crankshaft. Joe-JDC
Visits: 4.5K
thanks guys for the clarifications, I have the crankshaft in the machine and I didn't check, the model
Posts: 7.5K,
Visits: 205.8K
Visits: 4.5K
Thank you for the images, and which one is more desirable?
