Spark Plugs
Posted By customline3859 5 Years Ago
Spark Plugs
customline3859
Question Posted 5 Years Ago
Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)
Posts: 80, Visits: 979
Just wondering what spark plugs you would suggest for a mild street engine. Here is my setup, I will be adding an AOD transmission for better highway manners.
292 .080 over (304)
Fenton Tri Power intake
mild cylinder head porting. (gasket matching ecz-g heads)
red's headers
pertronix ignition and coil
isky 301333 cam
  • Valve Lift Int/Ext. 0.448
  • Valve Lash Hot Int/Ext. 0.020
  • ADV Duration Int/Ext. 270
  • 0.050 Duration Int/Ext. 228
  • Lobe Center 112
Posted 5 Years Ago
Posts: 1.2K, Visits: 285.6K
My 292 +.060" has the same heads, cam and ignition.   I use Autolite #46s.  Never had a problem.
71% of original size (was 710x19) - Click to enlargehttp://forums.y-blocksforever.com/uploads/images/82ad85c1-6def-4eb4-a085-3dd2.jpg
customline3859
Posted 5 Years Ago
Excellent. I'll go with that. How does yours run? I'm curious what to expect.
Posted 5 Years Ago
customline3859 (1/20/2020)
It runs great.  I love that cam.  Great mid range torque.  My car has a manual transmission with O/D and a 4.11 gear.  The 465 cfm Holley carb is perfect for the street.  Idles at 800 rpm with just the right lope.  You are not going to run down any Hemi Challengers, but it has plenty of grunt.
1 active, 1 guest, 0 members, 0 anonymous.
No members currently viewing this topic!
