Posts: 3.3K,
Visits: 238.8K
Can't find the 2- 90 degree master cylinder brake switch plug in connectors, for a 57 Ford, at any of the 3 parts places I've checked in western Canada, including NAPA. Can get straight ones, but they are rather vunerable in that location. Mine are likely original & just taped together barely.. Thanks..
Posts: 2.0K,
Visits: 306.5K
Posts: 3.3K,
Visits: 238.8K
Thanks, they look like they should fit, although they are listed as for Power Brakes? Mine are manual, so ? P.S. Kultults- says the're o.k., thanks for the clarification.. P.S. II- also found them listed in an older Dennis Carpenter Catalogue as Female pigtails B6A-13644-R & at a lower price..
Posts: 2.0K,
Visits: 306.5K
Should be no difference as both applications take the same switch. You gotta watch these vendors.
Visits: 7.3K
You're a good man Charlie Brown. Thanks for the info. I just used a female spade lug. This is much better.
Buz
