Looks like they can be spotted by the difference in the length of the pushrod oiling hole material.
Visits: 323.8K
Kultulz, I checked a B-2 rocker, again a random pick from my pile. The OAL is 2.960, and the same 15/64 drill fit. They had no screws, I put self locking screws in them to check the drill bit clearance. Mike, did you find an A-2 rocker to complete your set?
Last Active: 9 hours ago
Posts: 2.0K,
Visits: 306.5K
HOOSIER HURRICANE Posted-
I picked a random A-2 rocker arm out of my stash. The OAL length is 2.950" and a 15/64" drill bit is a tight fit between the rocker body and the ball on the adjuster screw.
... hmmph ...
Now it is becoming confusing ...
THANX for your time and trouble ...
Visits: 21.8K
No haven't completed my A2 set but do have a B2 set so maybe ok now. Thanks MIKE
famdoc3 (11/16/2019)
Have 15 good ones and 1 1.43 replacement. Am currently rebuilding my shafts Fo my 471 blower motor. Thanks for the help. MIKE The person that sent you that rocker that ended up being missing due to a torn package gave to me the remainder of his oem stash of Y parts. There are still some random NOS 1.54:1 ‘A2’ rockers remaining but none of them have the adjusters or lock nuts in them. If you still need one less the adjuster and nut, let me know and I’ll get it into the mail for you. I will need your mailing information again and you can send that to my email address. That can be found at www.eatonbalancing.com .
Visits: 21.8K
My rocker arm came today. Ted thanks for coming through. Now I have the 16!
