Visits: 3.4K
Here is the 55 272 that will be going in my 55 sunliner,its presently a 2 bbl but will be getting some 55 4 bbl heads along with 57 intake and exhaust manifolds along with a 62 distributor and 57 312 rocker arms and a 63 PCV system.
Posts: 2.0K,
Visits: 131.1K
Looks like a solid, oily core to begin with --- engines that look like these typically are not seized up and have decent internals to work with. Blessings on your build!
Visits: 3.4K
It is a runner and going to be dropped in as is except for the heads.
Visits: 3.4K
Got the C heads today along with the 4 bbl trans linkage parts in case I put the FOM back in.
Visits: 3.4K
Found the PCV parts and put them with the 62 valley pan and fit the FOM bellhousing to the FMX.
