Visits: 112.0K
I'm a little confused. I don't have the B manifold for the Y I'm building now and a friend gave me an A manifold. I always thought those has smaller runners then the B but these are the same size?
Last Active: 35 minutes ago
Visits: 22.5K
Is you manifold ECB-B, or ECZ-B? There is a significant difference. The ECZ-B is the later, better manifold. Joe-JDC
Visits: 112.0K
I have a ECZ-A, with the square carb mount but it has large ports/runners like the B manifold. I always thought they were smaller on the A manifold.
What are you comparing the ports to?
Visits: 112.0K
My G heads and the intake manifold gaskets. I thought I was going to have to blend the ports but I was surprised when I placed the gasket on to check that I didn't need to.
Posts: 1.8K,
Visits: 306.3K
The ECZ-A was the 1956 4V intake and the carb pad designed for the H4000. The 1957 ECZ-B was the 1957 4V intake and the pad size increased for the H4150. Supposedly the B flows better. TED EATON may have flow results in his TECH ARTICLES. Have you actually measured the runner size @ the cyl head mounting? The interior runner size on the B may also be larger.
Last Active: 5 Months Ago
Visits: 22.2K
the intakes were always smaller than the heads.
Visits: 112.0K
57RancheroJim (10/18/2019)
My G heads and the intake manifold gaskets. I thought I was going to have to blend the ports but I was surprised when I placed the gasket on to check that I didn't need to. Thank you, I Have always used the B manifold on my previous engines but this new engine I only have the A manifold to use. I'm not familiar with the A but thought the ports were smaller, thats why I was surprised they were the same size as the B. I did check it with the Gasket, the same Best gasket I use for the B..
Visits: 190.0K
if jim has a 57 2v manifold the ports are the same as the 4v.i have modified the 2v 57 to 4v and ports are the same,its a lot of work but works well, i have a used 57 4v so can compare the 2. the 56 4v is smaller ports with a adaptor does not work well in comparison
