Redline
Posted By Jim Yergin 7 Years Ago
Posts: 1.2K, Visits: 285.6K
In the early sixties most of our racing was "run what you brung" midnight street racing.  Most of those races where over early.  A hard leaving car was better than one that would rev to 7,000 rpm.  Fords had an advantage as they normally ran better in stock trim.  I had a 1957 Ford custom 300 with a 292, a three speed manual transmission and a 3.90 gear.  It wasn't the fastest car in the world, but it outran a lot of cars that claimed to be faster.
Later in the sixties, the game changed.   Factory muscle cars showed up with big blocks motors.  Back then you could buy a brand new 427 Ford medium riser engine in a wood crate for $1,200 from your local Ford dealer.  These motors came complete with carbs to oil pan.  You could put one of these engines into most anything and kick butt.  John Vermeersch in Detroit sold me some stroker pistons to make a 450 cu. in. 427 with a 428 crankshaft.  Here's an old photo below.
I ran that engine in a 1961 Starliner for a while, then transplanted it into a 1966 Fairlane.  The Fairlane was an all out race car with rear tubs and big Mickey Thompsons tucked inside the fender wheels.  It ran mid elevens at the drag strip.  I drove it on the street.  The drag strip opened around that time and we quit street racing.   When bracket racing came in, I lost interest.   Brake light racing is not racing.  These days all my racing is done on a bench.
http://forums.y-blocksforever.com/uploads/images/d1366cfa-8f77-4263-a8d9-ab2a.jpg
Posts: 2.0K, Visits: 306.6K
Two things caused the end of racing - SMOG/UNLEADED FUEL/INSURANCE and BRACKET RACING.
Never could figure out racing and it's cost to see how well the brakes worked.
That scrub had to be a SAT NIGHT SPECIAL with those rear ears.
DAMN I miss the night cruises and SAT @ the junk yards. And I miss reverberaters ...
The discussions on this part of the forum are technical in nature and very helpful.  We should start a thread somewhere else so we can talk about the old days.  I'm not sure the younger members would find it all that interesting.   Might be fun?
LordMrFord
Posts: 687, Visits: 9.3K
Florida_Phil (10/17/2019)
Y Blocks are torquey engines.  Scrubys rev.
Hollow Heads dragster revved 9178 in burnout when I forgot put the limiter on.
Sounded quite nice. Smile
Seppo might find that video clip from somewhere in his hard drive.
Hyvinkää, FI
..Getting back to Jim's original question!.. At some point years ago, Ford issued a bulletin about max RPMs for Y-Block regular stock valve trains. The max recommended was" 5400 RPM".  Of course this was not for Police kits or "F" code setups..  The real weak piece above  was likely the std. pushrods..
Note: Don't know if they are available anymore, but Schumann's Sales in Blue Grass Iowa used to advertise Police service valve train kits. H.D pushrods were sold seperately.  Also available was or is H.D. oil grooved Rocker Arm Shafts.. (J. Mummert sells the same ones I believe.)  Schumann's phone # is (563) 381-2416 or Fax (563) 381-2409.. ( No internet sales there)
Hollow Head
Posts: 1.0K, Visits: 3.8K
http://forums.y-blocksforever.com/uploads/images/f098f167-3062-4529-bc95-a1c8.png
That is the original Simo's data capture from that run. White line shows max peak rpm 9178 but that was just a sudden peak with tires loose... But, it didn't broke to that.  Stock forged crankshaft with Callies Compstar H profile 6.5 inch rods rated to 800 HP. Well, we have exceeded that by over 170 hp by the dyno sheet...
Jim Yergin
Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)
Posts: 22, Visits: 53.5K
Thank you Paul. That is good to know.
Jim Yergin
If you are going to rev a YBlock to 9,000 rpm, you better bring a butterfly net and a dust pan. (joke) Hehe
mark9088
Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)
Posts: 29, Visits: 8.2K
Old time heads-up racing is still alive in the nostalgia events/groups in the mid-west. check out nostagia gassers racing assoc., brew city gassers, great lakes gassers, etc.
http://forums.y-blocksforever.com/uploads/images/90f116af-b3cf-4452-823a-a9e5.jpg
GHOST vs HAULER 2017 (2).JPG (315 views, 132.00 KB)
Years ago I used to race regularly at Miami Hollywood Raceway Park and Moroso in Florida. I was walking though the pits one day and saw a Mustang drag car.  When I walked by to look at the engine, I almost fell over.  The Mustang had a YBlock with a custom sheet metal intake.  One of my friends told me it ran in a special class for early engines.  I don't remember seeing it run.
