Pertronix III module question
Posted By Danny 6 Years Ago
Danny
Posted 6 Years Ago
Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)
Last Active: 9 Months Ago
Posts: 132, Visits: 1.9K
Can someone tell me what model pertronix III (71281 or 71282) module I need for a 1956 Ford Crown Vic with a 312 yblock with an A1 Cardone 30-2808 remanufactured distributor which is the equivalent to the 1964 F100 yblock distributor? Pertronix tech said that he thinks the 71282 module is for the mid-fifties Ford yblock and that the 71281 module was for the later 1960s Ford yblock, but he isn't sure.
Danny
Posted 6 Years Ago
Last Active: 4 Weeks Ago
71281 57-74 Ford V-8. 71282 1954-1956 Ford V-8 with Loadomatic.
Gene Purser
Posted 6 Years Ago
Posts: 220, Visits: 6.0K
71281 is the unit for the later distributor. (1957 and up)
Posted 6 Years Ago
Last Active: 4 hours ago
Posts: 6.1K, Visits: 442.8K
Same as the small block for mechanical advance distributors so it should be 71281
Posted 6 Years Ago
Posts: 3.7K, Visits: 323.0K
The fact that the pertronix tech doesn't know sure doesn't do anything for my perception of their products and service.
Posted 6 Years Ago
Posts: 3.6K, Visits: 497.7K
X 2
Hoosier Hurricane (10/15/2019)
Posted 6 Years Ago
I believe he reason he said what he did was for stock distributors; remember these reps talk to a lot guys trying to trouble shoot problems and poor installations. The "2" would be for a loadmatic. If you told him it was for a 56 but with a later distributor installed it could easily cause confusion since these parts are not a big seller. I've been to their place of business in Ca. and found them extremely helpful. They even figured out a system for my friends flathead and actually installed the parts while we waited.
Posted 6 Years Ago
Posts: 1.8K, Visits: 306.3K
The fact of the matter is that in this time period was so confusing as you had both 6V and 12V systems, POS and NEG GRD, and LOAD-O-MATIC and DUAL ADVANCE. Add to that most buyers have no idea of what they have and/or modified. And then you have a SBF DIST on top of it also.
http://forums.y-blocksforever.com/uploads/images/027b8daf-5bbf-418f-a05f-fb2c.pnghttp://forums.y-blocksforever.com/uploads/images/65dc3ab0-27f4-4389-889c-df10.png
Talkwrench
Posted 6 Years Ago
Posts: 898, Visits: 23.2K
I'd have to check and see if I still have the packet.. Been in for a few years now, been great ! Multi spark through the entire rev range and rev limiter good bang for buck.
Posted 6 Years Ago
Danny (10/15/2019)
Danny
Have You checked that Distributor for correct Dimensions? Or is it 1/4" Short?
