Visits: 31.8K
Brass or steel ? Thanks
Visits: 8.4K
Brass
Visits: 153.3K
Steel
Visits: 498.0K
I'm on the brass side
Last Active: 4 days ago
Posts: 1.9K,
Visits: 194.9K
I’m inclined to use brass, especially if the engine is in the car and getting to it is difficult. It’s a little softer to drive in, or so it seemed. Either way I use a non hardening sealer and clean the block as best I can. On an engine stand with a boiled block, either steel or brass. I think brass is more forgiving of lack of maintenance (proper mix of anti freeze and changed as required), but if you're taking proper care, steel is fine.
Visits: 153.3K
I have no idea, I just figured somebody has to take the other side of the equation.
Visits: 183.3K
Cork.
"FREE SAMPLE"
Visits: 22.2K
factory used steel.
Visits: 153.3K
...that doesn't mean it was necessarily a good idea. In accounting, there used to be a term called the "Mill" which is 1/1000 of a dollar. If you pay property tax you already know about millage rates based on per $1000 value.
If the beancounters could save 1/4 cent on a part or gee-gaw, that was a big deal. Ain't corporations and horses built by committee grand?
Posts: 1.8K,
Visits: 306.4K
If using brass, you need to BRASSO them every so often -
