HEI Distributor Wiring on Positive Ground Ford Y Block
Posted By guiljones 6 Years Ago
guiljones
Posted 6 Years Ago
Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)
Posts: 9, Visits: 15
On my positive ground '55 F100 I wonder the following:
I'm thinking I run the + wire from the coil to the dizzy - wire?
Then what about the normal gr hepl would be appreciateound wire?
Any help would be much appreciated!
many thanks,
Guil
Posted 6 Years Ago
Last Active: 4 hours ago
Posts: 6.1K, Visits: 442.8K
Best to check with the manufacturer of the distributor.  Electronics cannot usually be wired two ways and the HEI distributors I'm aware are 12v. Your '55 is 6v,.
