Mummert Valley Cover Grommets
Posted By customline3859 7 Years Ago
customline3859
Problem Posted 7 Years Ago
Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)
Posts: 80, Visits: 979
Hello all. I ordered a valley cover w/ pcv from John Mummert a few months back. The package included the bolts to install the cover, and the pcv grommet. Unfortunately, it did not come with the two grommets required to bolt the cover in place. Is this correct? Was there a mistake made in shipping? Does anyone know where I can source these locally?
Thanks,
David
Joe-JDC
Posts: 798, Visits: 23.3K
Should be the same as the valve cover bolt rubber grommet.  Valve cover gasket set should have them for valve covers, and use two for the valley cover.  Joe-JDC
Last Active: 6 hours ago
Posts: 3.8K, Visits: 33.4K
The Valley Pan Gasket should include the Grommets. What are U using for a Gasket for Pan?
Posts: 7.6K, Visits: 206.1K
The pair of grommets for the two long bolts used to fasten the valley covers are typically not included with the aftermarket valley covers.  As previously mentioned, the grommets do come in the various gasket sets for the Ford Y.  They are the same grommet as used for the valve covers.  If you have trouble sourcing those by themselves, give me a call during business hours as I always have some extras laying loose.  My contact information is at www.eatonbalancing.com .  Ted Eaton.
A pass on note, posted here some time back by John, the Hoozier Hurricane. He noted that in some gasket sets, the rubber bolt rocker cover gaskets are apparently thicker than the original valley cover ones. He says that can result in some intake manfolds bottoming out on installation.. I trimmed the front one on my ECZ--B install, because it looked to be to close on clearance...
Posts: 3.7K, Visits: 498.3K
I have a bunch of the grommets your looking for.  Send me your address (PM) and I will send you a couple.
John Mummert
Posts: 919, Visits: 7.5K
I don't know if someone is building a new engine and has a complete gasket set or just replacing a valley cover.. If I included grommets the price would go up and anyone with a gasket set wouldn't need them. The only reason I include bolts is that if a bolt that is too long is installed to attached the valley cover it can hit a cam lobe!
http://ford-y-block.com
