Visits: 14.3K
Where is a good source for premade plug wires? I looked at a 7mm set from Magnecor but a $150 seems a little pricey to me. I also looked into Pertronix but theirs are over the valve cover and I would prefer to keep stock location. I'm buying a new dizzy and want upgrade the wires too.
Durham Missouri
Visits: 16.7K
Have you tried Dennis Carpenter or Mac's?... My method is to buy a semi custom set of wires, with the 90 degree plug ends installed You then route the wires, determine the length, and install the boot and distributor end.. A much neater looking installation than a pre made set Those always have some wires way to long and some too short.. It is not hard to do.
Posts: 1.8K,
Visits: 306.3K
Visits: 13.5K
Use wires for a 283 scruby (cheap)
Visits: 14.3K
Cliff, do are the 283 wires long enough to use in the stock location on a y block? Making my own is out. I'd rather take a beating than make plug wires. The Casco set is very appealing.
Durham Missouri
Last Active: 3 Weeks Ago
Visits: 32.6K
62bigwindow (8/15/2019)
Cliff, do are the 283 wires long enough to use in the stock location on a y block? Making my own is out. I'd rather take a beating than make plug wires. The Casco set is very appealing. Not sure if You noticed they will assemble Wires for labour $20.00. I have a chart from them showing Measurements for Brackets and Wires.
Visits: 22.2K
i got a nice set from napa.cheap
Visits: 22.2K
i checked and found part number BMX700106.less than 30.00
Visits: 13.5K
283 wires bolt right in
Visits: 442.8K
You have to bolt them in?
