Visits: 3.5K
The vacuum leak was caused by the PVC hook up. Thanks for your help, Tim Nearly Dead or Newly Wed, Florida 33706
Do the idle screws stall the engine now and are the manifold temps better?
Visits: 3.5K
Idle screws open two turns, perfect idle and curb idle is set a 626 rpm. Car runs better and seems more responsive............me happy Big time thanks for your help and time, Tim (Hot 'n Humid) Florida
But does it stall if one or the other screw is turned all the way in? Verify that it does and all is probably well with the carburetor, now.
Visits: 23.2K
Last Active: 9 days ago
Visits: 32.6K
Talkwrench (6/16/2019)
Looks like all fixed , Sounds like it was carb issues that Charlie ran you through .. Just wondering if you still had an exhaust / heater flap in one of the manifolds? Heat Riser Valve. Good Point. They tend to seize up.
