Posts: 3.8K,
Visits: 33.3K
Hello Steve,The response is exactly what I was hoping for from everyone who has answered.(thanks for your input)I think I am going to seriously look at the 525 road demon.Theres one on Ebay now as a factory reman at $249.00 plus mailing to Canada.What was the "fix" that John gave you regarding sticky I assume inlet needle and seat?I am a rookie at setting up these replacement 4bbls.As someone of average(or less)intelligence are they hard to setup?I have a manifold on the way.What else do I need to this swap properly such as a spacer plate?I see some phenolic ones on Ebay for Holley application.Should I be getting one of those? What is the best one to use?Any other suggestions?Thanks, Mark
GREENBIRD56
Visits: 102.7K
John mentioned in a old post that the Viton tipped needle and seats were being "attacked" and apparently softened by the new generation of alcohol and additive laced fuels. A sticky situation - and mine were sticking. His solution was to use stainless steel needle and seat assemblies. I don't have it under my nose - but there is a Holley part number for a pair of .130 orfice needle and seat assemblies (for an alcohol carb) that is reasonably priced and easily solves the problem. They screw right into the Demon carb - just try to match the installed height you found on the assembly you are replacing, to avoid a flooding situation when you start it up to set the float level. I did mine one at a time to avoid a double trouble overflow situation. Both could be installed dry by removing the bowls and setting them in the inverted position - I was just lazy.... One thing about the Demon that has caused me a bit of trouble - it has a fairly stiff integral throttle return spring. This has raised some difficulties with the stocker Ford-o-Matic kickdown system - but a stick shift car would never notice. Don't settle on a spacer until you have the carb and get a look at the throttle bores - they are significantly larger than the bores in the late four barrel manifold (9425-B). It will require modifications to the manifold - or some massaging of a phenolic spacer to create an adapter capable of "funneling" the larger carb bore down to the manifold size.
Steve Metzger Tucson, Arizona
Posts: 3.8K,
Visits: 33.3K
Thanks Steve,What is required to match manifold to carb?Boring the holes larger in the manifold or can the spacer be tapered to match carb on one end and smaller holes in the manifold on the other?Thanks for your help.Regards Mark
Doug T
Visits: 2.6K
With regards to grinding the manifold, if you want to get better performance with the Iron manifold grind the flange area out like this. Be sure to remove the sharp end edges where the holes enter the "roof" of the passage. Also eliminate the pinch point where the passage dives down and under. Your can just see that place in the pic in the right passage. I glass bead and fill the flange with high temp epoxy mixed with the iron filings that result from the grinding. This has not been done on this manifold yet. Use a plastic spacer under the carb. 1/2 or 1 inch max performance is a single square hole spacer. Smoother operation is with a 4 hole spacer and is recommended for street. These modifications will support over 300HP with other engine mods. And with a proper metal spacer this could probably be done to '55 and '56 manifolds also so that a more modern carb could be used.
Doug T
charliemccraney (7/19/2008) I have been thinking about getting a smaller carburetor. From what I've learned in the time since I bought the carburetor I think the 600 is more than I need. I've noticed that the Demon 525's are mostly for engines with cams that have less than 200 @ .050. I've found one that is less than 220 @ .050. Will it be easy to tune it to work with a bigger cam - 226 @ .050? Or may there be more complicated issues? I've also considered the Thunder AVS - with the adjustable vacuum secondaries.Charlie. The camshaft in my 272 is 216° @ 0.050” with the lobe centers being ground on 108° and the 525 cfm Demon Jr. is fine with this. There will be a certain point where the manifold vacuum drops off enough that the idle bleed holes will need to be tinkered with and this is where screw in air bleeds would be nice. But those screw in air bleeds would appear to only be available on the higher end carbs and those of a larger cfm capacity without going to the trouble of retrofitting a non-equipped carb with them. With the pressed in bleeds, it’s trial and error on addressing idle and low rpm fuel mixture issues with a much larger than normal camshaft. Changes are typically made in 0.003" increments. But if it makes you feel any better, the Road Demons and Speed Demons basically have the same size idle bleeds and I have ran both on a Y with the 254° @ 0.050” camshaft without major differences in idle quality.
rgrove
Visits: 3.5K
Ted (7/19/2008)
Seems to be a misconception out there that large carburetors make an engine run richer. In reality, the engines actually run leaner if the carb is oversized. Ted, I didnt intend to reinforce/perpetuate that myth; sorry if it came across that way. I certainly understand/agree with your (and others) previous explanations on bigger carbs running leaner. I was just commenting on how my 500 cfm showed a LOT of fuel dilution on a UOA vs. the 390. May have been as much an issue of the carb itself as the size... I have yet to find a setup that is really all I want it to be; for starters I cant really pull much more than about 10 in hg at idle... but that is a question for another thread!
Ron Grove Wauconda, IL
ejstith
Visits: 1.0K
I just put an "out of the box" Holley 390 on my 272 with a 57 up manifold. I converted the ignition to a 57 up distributor with a Mallory electronic kit, new MSD 7mm plug wires and Autolite platnium plugs. Fired right up, set the timing and am good to go. Works fine and I never fiddled with anything.
E.J. in Havana FL
Thanks, Ted. If it worked on your 254 deg cam then I probably will not have much trouble. In fact, I was looking at my Edelbrock book last night and it says that the 600 I am currently using is for cams with less than 220 degrees as well. I'm also curious about what makes the difference between the edelbrock 600 and 500 carbs. The book says that the primary and secondary bores are the same, as well as the venturi diameters. An Edelbrock 500 will be easiest for me to swap but if you all are having good results with the demon... Do the Demon carbs use Holley jets and power valves? I haven't noticed any Demon jets or valves.
charliemccraney (7/25/2008) Do the Demon carbs use Holley jets and power valves? I haven't noticed any Demon jets or valves.The gaskets, needle seats, jets, and power valves are basically interchangable between the Holley and Demon carbs.
y-block don
Last Active: 15 Years Ago
Visits: 478
i cannt agree more on the demon carbs they are slick and nice  thats what wil be going on my 55 vic as soon as i get the intake changed over
y-block newbie
