Visits: 10.6K
For sale 1956 mercury 4 dr.sedan 46, 000 original miles .Original 312 factory 4 barrel . Runs good ,Dual exhaust needs mufflers. T85 3 speed with overdrive works as should passing gear and all .Dana rear 4.09 ratio. New aluminum radiator, new fuel tank with s/s straps, new fuel lines ,carb rebuilt new fuel pump .New wheel cyls. 4 wheels. New master cyl. All new brake lines & hoses. New engine mounts. New clutch and pressure plate & fly wheel resurfaced. Has an interesting accessory installed .Marvel Mystery Inverse Oiler????. Petronix set installed in distributor [sure makes for quick starting] new plugs and wires installed .Body needs rocker panels & below head lites and has some dents from an older person driving. NOT ME. $4,000 Cash To get an excellent look at this car go to Cincinnati Ohio Craigs List under cars by owner . Put in # 6890647917 for 24 pictures Thanks Call Harry 513-868-3311 no text If I miss you leave message and I will return call. Note Engine casting # ECZ B South West Ohio 18 miles from 2019 Y Block Shoot Out
Note if I don,t sell this I will make this engine and drive train availably
Visits: 306.2K
https://cincinnati.craigslist.org/cto/d/hamilton-1956-mercury-monterey-4-dr/6890647917.html
Visits: 10.6K
Kultulz Thanks Harry
