1954 6 cyl zbar
Posted By rotten roger 6 Years Ago
rotten roger
Posted 6 Years Ago
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Posts: 2, Visits: 65
Newbie here with a question. I have a 6cyl 3speed clutch  zbar, 7 inch overall length. Can I shorten it and to what length for a v8. I'm building a 1954 Courier and using a 1954 mercury 256 cu engine with 3 speed from my stock 239 setup. The car has been apart for years and many of the parts have gone into hiding so the zbar is from a 53 6cyl. Hope this is the right place to post a question.
Thanks Rotten Roger
Posted 6 Years Ago
Looking at the parts manual, the six cylinder and eight cylinder z-bars are the same.  The bars themselves are year model specific so if adapting a z-bar from a different year, some modifications may be required.
http://forums.y-blocksforever.com/uploads/images/604955ff-e2f1-40d8-a3e5-2257.jpg
rotten roger
Posted 6 Years Ago
Thank You Ted, Modification is in my future.  Rotten Roger
Posted 6 Years Ago
Posts: 3.6K, Visits: 497.7K
While I agree with Ted that both 6 and 8 cylinder seem to be the same, if the Z bar is from a 53 then it may not fit as it has a different part number.  If the 53  does not work, I have a very good 54 Z bar for sale.  PM or email me
Posted 6 Years Ago
Posts: 4.6K, Visits: 38.4K
Will this work?   https://www.facebook.com/groups/193973717381378/?multi_permalinks=2009944215784310&notif_id=1554953086854791&notif_t=group_activity
62bigwindow
Posted 6 Years Ago
Posts: 884, Visits: 14.3K
When I pulled the swapped out the 223 for a y block I kept the original z bar. Yours will be the same. All it needed was a adjustment.
Durham Missouri
Posted 6 Years Ago
The 55 Z bar will fit with no problems.  I used one of those on my 54.  If you  want dual exhaust with the factory manifolds, then the 55 works to clear the stock pipes.
62bigwindow
Posted 6 Years Ago
I totally missed that you were using a 53 z bar. I would take up Paul's offer in the one he has for sale.
Durham Missouri
