Certrifical Advanace Modification
Posted By Florida_Phil 6 Years Ago
Question Posted 6 Years Ago
Posts: 1.2K, Visits: 285.6K
My 292 is running a stock 1957 ball bearing style distributor with a Pertronix Unit.  I have the vacuum advance disconnected and the total timing set at 36 degrees. My engine idles and runs great.  I wish to bring my distributor advance all in by 3,000 RPM.  I do not have access to a distributor machine.  Back in the day we swapped springs around to "curve" the distributor.   Can I make this happen with just a timing light?
Posted 6 Years Ago
Last Active: 9 hours ago
Posts: 6.1K, Visits: 442.5K
You can.  A diagnostic tachometer would also be helpful so you can more easily see the rpm at the same time.
