Posts: 3.8K,
Visits: 33.4K
Sounds pretty uncomfortable. Got to look at the Bright Side Paul. At least You are still around to feel the Pain. Get better soon.
Last Active: 7 Months Ago
Visits: 559
I have had the old ford matics loaded on the trailer , ready to tie down , pop out of park and roll off the trailer ,before I could chock them up. Now , I tie them down and screw 2 by 4's on both front and back , no issues now . Po ol Davie
Po ol DavieSparta , Tn.
Visits: 14.6K
I use a big rubber chock I found by the side of the road years ago. It must have fallen of a large truck. I had something similar happen to me years ago while I was adjusting the idle on a 67 Cadillac in my garage. I had the parking brake on while the car was in drive. Something happened and it lurched forward. There was about a foot of space between the car and the wall. It nearly pinned me but I moved out of the way in time. The front bumper punched some nice holes in the wall and I got bruised as well.
~DJ~ AKA "Bleach" 1956 Ford Fairlane Town Sedan 30K original miles
Visits: 2.9K
Cars jumping in gear is the exact reason that newer vehicles won't come out of park without pressing on the brake pedal. My dad had a 72 torino jump out of gear into reverse just as he was getting into it. Lucky that time. In the 80's he left a tempo in drive and shut it off. Took the key out and walked in the house. 1/2hour later a neighbor was knocking telling him the car was across the road. Lucky no damage or anyone hurt!!
Visits: 14.6K
Ford sent out these stupid stickers in the 80's. It was to save their ass from a 23 million car recall of Fords with automatic transmission built between 1966 to 1980.
Posts: 3.3K,
Visits: 238.8K
P.S.- follow up; Investigating my accident, I found that the lift lever latching for Park, was not engaging properly into the indent on the steering wheel hub. It appeared that I should be able to adjust the length of the threaded shift rod down to the transmission to engage better. In doing so it might also center the quadrent readout better... However, apparently adjustabilty is quite limited, because when I did adjust it a fair amount, it still didn't latch really well & then the car would no longer start in the "neutral" position. Obviously that is not satisfactory! Another factor involved here possibly, is that the entire steering column was out of the car some years ago, & maybe there is some misalignment in the reinstall ?.. Any suggestions anyone?
