1963 F100 transmission clutch size
Posted By 63pikup 6 Years Ago
63pikup
Posted 6 Years Ago
Hitting on all eight cylinders (7 reputation)Hitting on all eight cylinders (7 reputation)Hitting on all eight cylinders (7 reputation)Hitting on all eight cylinders (7 reputation)Hitting on all eight cylinders (7 reputation)Hitting on all eight cylinders (7 reputation)Hitting on all eight cylinders (7 reputation)Hitting on all eight cylinders (7 reputation)Hitting on all eight cylinders (7 reputation)
Posts: 4, Visits: 20
1963 F100 , 312, 3 on the tree. not sure what trans is best for daily driver. clutch is 11" 10spline. does this sound like a winning combination? and whats the consensus for best clutch? we don't plan on driving  more than 50mi/day
Posted 6 Years Ago
Posts: 3.6K, Visits: 497.7K
I've used Centerforce dual friction clutches in two of my cars with no problems.  One has been in the car over 12 years.
Posted 6 Years Ago
Posts: 6.1K, Visits: 442.8K
Without a lot of work the 3 speed is about the best for a daily driver. Anything else will require quite a bit of money and time.
If the truck is stock, get a quality stock replacement clutch.
Posted 6 Years Ago
The 64 or 65 and up  V8 three speeds were first gear  syncro but I don't know if the mounting bolt pattern will fit the bellhousing.  And you may have to make some small mods to the trans.
