Visits: 136
need some info guys just took apart a 312 I understand there is a spacer between the cam and cam retainer plate this engine did not have one my question is with the spacer in place does it keep the retainer plate from sitting flat against the block to the best of my knowledge this engine has not been taken apart before it did have a keyed spacer in front of the timing gear any info would be helpful thanks
Last Active: 56 minutes ago
Visits: 38.4K
Visits: 442.8K
There is no spacer between the cam and plate. There is a spacer between the cam and timing gear. That spacer fits within the diameter of the retaining plate and is a little thicker than the plate, which sets the camshaft end play. That spacer is 6265 in the drawing. If that is missing then the engine was not running and probably would not even turn over.
Visits: 285.6K
I fought this battle last summer when I rebuilt the 292 engine in my TBird. The engine that came in my car was a mismatch of parts from at least three different engines. I had zero cam end play with the new cam and gears. I was lucky enough to have another engine to rob parts from. There are differences in some thrust plates and spacers. The right combination of parts will yield about 5-10 thousandths cam end play. What I did was mock up the cam, spacers and gears in my block and check the end play without the lifters and timing chain. If I had run my engine with the mismatched parts I'm sure it wouldn't have lasted very long.
Last Active: 4 hours ago
Posts: 7.5K,
Visits: 205.8K
Visits: 22.2K
i took apart one last year and noticed the teeth were worn on the edge of the cam gear.they had taken the spacer that goes in front of the cam gear and put it behind pushing the gear out 1/8 of an inch.diidnt hurt a thing.the enging had about 30.000 on it.
Visits: 38.4K
It's also not uncommon to switch the two spacers. The chamfered one must be first and face the camshaft. Also note the front spacer is optional with the 6290 counterweight.
Visits: 136
thanks for the info big help
