Oil bath air cleaner convertor.
Posted By weasel 7 Years Ago
weasel
Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)
Posts: 15, Visits: 20.9K
I have a 1954 Monarch (Merc) oil bath air cleaner from a tea pot carb. I have installed  a 292 Holley 4150 4bbl carb. I want to adapt or find an adapter that will allow me to use the oil bath air cleaner on the Holley. Any suggestions.
Bert
darrell
Posts: 457, Visits: 22.3K
it should fit i know a 55 tea pot breather will fit a holley.mybe the 54 is different
The 1953/1954 Holley model 2140 4V carb has the same air cleaner flange as the 1955/1956 Holley model 4000 carbs as well as the 1957 & newer Holley 4150/4160 carbs .  See if this link to a past thread helps.  This was a 4V Teapot air cleaner that was converted to a paper element design while also being fitted to a Summit 750 cfm carb.  The Summit carb has the same carb flange as your model 4150 Holley.
http://forums.y-blocksforever.com/Topic131104.aspx
Posts: 3.8K, Visits: 33.2K
weasel (2/21/2019)
Bert
I have the original Oil Bath ( now Dry) on my Holley. I just had to bend the 2 Tabs on the Bottom flat so it would sit on the 4160.
http://forums.y-blocksforever.com/uploads/images/897f63e1-6ab5-460b-b0db-7306.jpg0 Flange.
The photos were done when I replaced the Holley with a small base WCFB. I bought another air cleaner off E-Bay and second adapter on the WCFB is for a large carb flange which would be right for you. I cut the bottom out of the main body and mig spotted the top to the body. Painted with Eastwood Argent.http://forums.y-blocksforever.com/uploads/images/06c95b06-df47-4b8e-bf61-c115.jpghttp://forums.y-blocksforever.com/uploads/images/f9f749b0-385f-481e-bfac-dbc4.jpghttp://forums.y-blocksforever.com/uploads/images/183fb6c3-e2db-4515-a469-91c5.jpghttp://forums.y-blocksforever.com/uploads/images/3adee9d0-4a2b-4d21-aa0f-f4ff.jpg
