Visits: 10.6K
Reading Ted`s 57 Fairlane 292 rebuild in Y Block Magazine ,Ted mentioned stretching the main caps for a better fit in the block. I have had many different [,including 2 air craft ] engines apart and never heard of stretching main caps. Ted or some one help me here on how that is done , or is it like resizing pistons ? You learn something new every day. Thanks Harry Hutten
Visits: 285.6K
Previous to my latest Y Block build, I had never had a block align bored. When I took my 292 block to the machinist, we found out it was a mess. One side was lower than the other and the main caps were walking around. The crank had been welded and the rods were mismatched. It had already been bored .040 over. These old engines have seen a lot of duty. Not all of them were assembled by the greatest mechanics. After much machine work, I was finally able to get a decent block. I combined another motor I had laying around, now have a decent motor that should last a while. Check everything before you assume anything. Here's another tip. Make sure your machinist has some Y Block experience. Few do.
Visits: 206.1K
hjh (1/24/2019)
Reading Ted`s 57 Fairlane 292 rebuild in Y Block Magazine ,Ted mentioned stretching the main caps for a better fit in the block. I have had many different [,including 2 air craft ] engines apart and never heard of stretching main caps. Ted or some one help me here on how that is done , or is it like resizing pistons ? You learn something new every day. Thanks Harry Hutten The loose caps have a memory for staying loose so they do want to resort back to the ‘collapsed’ value and remain loose if doing anything short of heating them up and getting serious with them. Prior to align honing the block with ‘loose’ main caps, here’s what is done to get those caps tight once again in their block registers. With the caps in a vise so there is an outward pressure being applied that temporarily expands the width of the cap, heat is applied with a rosebud torch. Once the cap cools, it is measured for width and compared to the width (register) in the block where it resides. If the cap is 0.002-0.003” wider than the block register, then all is good. If the cap still falls short, it’s reheated again in the same manner until the aforementioned press fit values are attained. This is a lengthy process and many times if one cap is loose, you’ll also find several others if not all that are also loose. Each cap must be individually worked on.
Last Active: 2 Weeks Ago
Visits: 1.4K
What is this y-block magazine?? Any info you can give me??
Visits: 31.2K
Jack Groat (1/26/2019)
What is this y-block magazine?? Any info you can give me?? It is a magazine supposedly put out by a guy named Bruce Young. A link can be found at the link button. Good luck contacting him, I have tried numerous times to subscribe with no luck, or he never gets my emails. I will not call as I do not hear well. Any info I need I can get here or from Ted's web site, but I am a voracious reader and pretty much read anything. Dave
Visits: 206.1K
