Posts: 7.5K,
Visits: 205.8K
Lou (1/17/2019) Buy a spare radiator, with out the study rest you might need one after a really hard stop.PF Arcand(1/18/2019) I don't own a 55-56 ford, but without the "steadyrest," how secure is the engine if the transmission is removed? The installed front engine steady rest was part of the better ride those ’54-’56 Fords were noted for. But doing away with the steady rest didn’t kill that ride or the dependability of the car. Those steady rests were over kill in regards to engineering and were eliminated on the ’57 and newer models. I put FE’s in a majority of those early Fords back in the day and the steady rest was the first thing to get rid of. Besides those steady rests not bolting up to the FE engines, they were simply in the way. The Ford frames were boxed very well so the flex seen in the ‘C’ car frames was not an issue in our older Fords which is where the over-engineering of the Ford cars comes into play. In eliminating the steady rest, there are no issues with engines coming forward on hard stops as long as the existing engine and transmission mounts are in fair condition.
Rusty_S85
Visits: 2.7K
Guess I should consider myself lucky as my old '56 still sports the gravel shield under the engine as well as the steady rest.
About the same as every car built after 61. Exhaust pipes held up most of the one I worked on.....
Brent
Last Active: 10 Months Ago
Visits: 1.5K
Last Active: 6 days ago
Visits: 32.6K
Different style Steady Rest.
Posts: 1.8K,
Visits: 306.3K
Are the Fairlane engine mounts the same as the Thunderbird?
The BIRD has a different and very unique mounting system.
Visits: 497.8K
What looks like steady rest in a Tbird (and trucks) is actually the front mount. TBirds used "steady rests" on both sides of the block Brent (1/18/2019)
Rusty_S85
Visits: 2.7K
Yep there are differences. Here is the T-bird steady rest which is actually called a front support in this case.  Here is the engine side support for the Thunderbird.  Here is the engine support for 54 and up cars  And the car steady rest which I couldn't find in the parts and illustration guide but there is a illustration in the 1956 shop manual I have.
The trans shop and I both caused a problem with the harmonic part of the front damper to make contact with the steady rest. I repaired the problem and later found that contact moved the timing mark. I was able to get a damper from a friend and I have it rebuilt and now am changing it. I've decided to remove the "steady rest" and have a question for those who have done it, The portion of the mount where the large bolt from the bottom go thru still sticks out in the way. How many have cut it off? The mount must stay because it looks it part of the radiator framing and is spring mounted. The auto trans cooling lines were a pain to remove with the steady rest in there.
Posts: 1.8K,
Visits: 306.3K
... hmmpf ... Never thought of that. THANX for the wake-up call. Newly learned FACTOID of THE DAY.
The mount is part of the front cross-member (5019). You could cut the flange but leave the mounting section for the core support.
