Brent
I received the Summit fuel sender today
https://www.summitracing.com/parts/tnk-556fsA few quick notes first. I mounted it in a wood test mount so I could get more accurate readings than holding the thing in my hand and holding test probes while moving the float up and down. I also connected the Ohm Meter leads using ring terminals so intermitent connections would not skew the readings.
First test resulted in "0" ohms full and empty, Looking around the sender I found that the connection stud had a lump of solder that was touching the case. I found that loosing the jamb nut and rotating the stud it would clear the case (dont go to far or you will break the wire that the solder is attaching)
Now that I have repaired my brand new sender here are the results Full - 35 Ohms 1/2 - 131 Ohms Empty - 266 Ohms
Using the Digital meter the readings were very jumpy, The analog meter read smoother but did jump in certain spots around 1/2 tank. I am thinking that the resistance element may have some kind of oil on it that installation in a real gas tank would wash off and smooth out the operation.
If I get time over the weekend I am going to take it out to the car, remove the sender wire from the gauge and wire and ground the new sender out of the tank and see how it works on an actual gauge
Will report back
