	            Group: Forum MembersLast Active: 3 Months Ago
                Visits: 1.4K
                I am looking for pistons with rings (.03 or .04 over) for a 292 rebuild.  I would like about 10:1 compression when finished.  I want to run available premium pump gas.  All the ones I have found so far are flat tops.  I would like to find some high domes to get to my chosen compression ratio.  I plan on buying Mummert aluminum heads.  Any suggestions where I can find some??
	            Group: Forum MembersLast Active: 2 Years Ago
 Posts: 1.4K,
                Visits: 179.6K
                Jack.  John Mummert is offering a forged piston with a 10cc dome.  Click the link below for a chart John has on his web site that indicates the static compression ratio that will be yielded with various bore and stroke combinations used with different cylinder heads.http://www.ford-y-block.com/forgpiststk.htm Hope this helps!    NoShortcuts a.k.a. Charlie Brown
	            Group: ModeratorsLast Active: Yesterday
                Visits: 442.8K
                Mummert had domed pistons at one time.  If he doesn't then they will probably have to be custom ordered.
	            Group: AdministratorsLast Active: Yesterday
 Posts: 7.5K,
                Visits: 205.8K
                Visits: 1.4K
                Great response guys..  I talked to Mummert and he said he did not have any of the domed pistons.  But it looks like I can get close to 10:1 with flat tops and aluminum heads.
	            Group: Forum MembersLast Active: 2 Weeks Ago
 Posts: 1.9K,
                Visits: 194.9K
                I’m just going to add a comment.  I’m running a stroker motor, 3.811 bore, 3.510 stroke, 320 cid.  Pistons .010 down.  I pulled the ported cc’d 113 heads and installed a set of Mummert’s aluminum heads.  This put my combo over 10.5, and detonation on street fuel was a problem.  We did a cam change to lower the dynamic ratio a bit, and with proper timing all worked out ok.
 But when we pulled the heads, the pistons had a consider area with clean aluminum.  Now, I don’t really know what this means, but I know a lack of flame travel has to do with the quench area.  Which is a mystery to me, I just can’t seem to get my head around it.
 Hopefully, someone will explain it, and I know the stroker displacement affects the compression ratio.  My point is you need to look at the combustion chamber volume and shape.  It’s real easy to get into detonation problems from other than just static ratio.
 Ted Eaton and John Mummert were very helpfull in arriving at the new cam specs, but in  retrospect I should have probably cut and rebalanced the pistons.
 Posts: 7.5K,
                Visits: 205.8K
                miker (12/5/2018) ......But when we pulled the heads, the pistons had a consider area with clean aluminum.  Now, I don’t really know what this means, but I know a lack of flame travel has to do with the quench area.  Which is a mystery to me, I just can’t seem to get my head around it.  ......The clean piston tops could be the result different things of which a combination of them could be at play.  Minimum quench will be one, too much piston to head clearance could be another, and fuel wash could be yet another.  If a result of being from minimal quench, then I’d not be worried about it.  Fuel wash in itself could be a result of just a rich fuel mixture, inadequate atomization of the fuel at the carb venturies, poor fuel distribution from the intake port, or a lot of camshaft overlap which is typically the result of a reduced lobe centerline and poor exhaust scavenging taking place.  Low rpms creates many of the aforementioned scenarios but a restricted exhaust system is also a player.
   Lorena, Texas  (South of Waco)
 Posts: 1.9K,
                Visits: 194.9K
                Thanks Ted.  With the EFI, FPA headers, 2 1/2” exhaust, we were thinking minimum quench.  The a/f ratios are good on the dyno and when driving.  Low rpm doesn’t happen that much with me driving.
