Visits: 1.8K
i'am looking for brackets for a/c compressor (sanden). this needs to be a mount for lower pass. side mount. also, need crank pulley for my '56 y block. 724 733 8402 pgh.pa.
Posts: 2.0K,
Visits: 130.3K
If you cannot find anything used from someone on the forum here, may I suggest something like what I purchased? There is a full write up and photos here: https://www.hotrodreverend.com/single-post/2017/09/30/55-Ford-Fairlane-Restoration-Blog-Part-18dan jessup
Last Active: 34 minutes ago
Posts: 3.6K,
Visits: 497.6K
A number of years ago I bought a combination alternator and compressor mount from Vintage Air so check with them. Part # 15114-VFB. It mounted the alternator on top, the compressor below
Last Active: 10 hours ago
Posts: 7.4K,
Visits: 205.6K
As an alternate A/C bracket supplier to Vintage Air in San Antonio, you might check out what is available from Ford Craft (Don Hyde) in Dallas, TX.
