Thunderbird Power Steering
Posted By Brent 7 Years Ago
Brent
Last Active: 8 Months Ago
Posts: 142, Visits: 1.5K
I am in the process of rebuilding the power steering for my ’55Thunderbird.
I have the Early Pump which returns to the pump body,
I have a choice of using either:
2-Tooth (AD3550A) or  3-Tooth (AF3550A) Gear Box
Early Ram Cylinder – 2-1/8” or Late Ram Cylinder – 1-11/16”
Early or Late Control Valve
The size difference of the Early Ram (bigger’s better?) makes me wonder if I should use the Early Ram with the Late 3-tooth Gear and the Late Control Valve (typically late is better?)
Any insights would be greatly appreciated.
I will use Lares Corp to rebuild the parts. I found them as a result of searching through the archives. Y-BlocksForever is the best tool I have. THANKS!!!
https://www.larescorp.com/
