56 Ford-O-Matic Transmission is leaking
Posted By KVBruce 7 Years Ago
KVBruce
Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)
Posts: 4, Visits: 793
I have a 1956 Victoria with a 292, auto trans. The trans is leaking at the front seal. Has anyone had any luck with a stop-leak product or should I just plan on dropping it and having it overhauled? Any thoughts would be appreciated. Is it something that could be done under a "shade tree"??
darrell
Posts: 455, Visits: 22.2K
in most cases replacement of the seal is the only answer.
2721955meteor
Posts: 927, Visits: 190.0K
while it is out check the front pump,the bushing is often worn as well as drive tangs torqe to front pump,check this aria or you will be having leaks shortly after repair. this repair does not  mean the trans is in need of overhaul. if  it shifts well thats as far as you need go. just my exp.
KVBruce
Is the seal replacement something that could be done on my shop bench??
KVBruce
Where would be a good source of an overhaul manual for this transmission??
Last Active: 4 Weeks Ago
KVBruce (11/25/2018)
Ebay Item 273279940911. The Front Pump Seal can be replaced easily once You have the Transmission out. I would suggest replacing the Shifter Arm Seal while U have it out. Shifter Seal # FO-15 from ATP includes the O ring as well as the Seal. Pump Seal # National 6988H. I have my Fordo out now to replace those Seals as well as the Seals in the Engine. My Project for the Winter.
Pete 55Tbird
Posts: 721, Visits: 93.2K
Leaking trans seal. NOT A FIX but a Band-Aid I have used with mixed results. Your MILAGE MAY VERY. Lucas trans SNAKE OIL it
causes the rubber seal to swell up and POSSIBLY stop your leak. Until you unload the car or FIX IT. Pete
Lord Gaga
Posts: 464, Visits: 183.3K
Try "Trans-X". It stopped the leak in the front seal of the C-6 in my van!
"FREE SAMPLE"
KVBruce
Thanks Pete, I really didn't that stuff works but I never say "never". I've got the engine out of my boat right now, so the 56 will have to wait in line.
