Visits: 32.6K
I am getting the Motor in my 56 ready to pull so I can reseal and repaint. There is a Draincock on each Side of the Block. Do they drain all remaining Coolant from the Block. In other Words are they at the lowest Point in the Water Jackets?
Visits: 442.8K
They will drain most of it. They are the lowest possible place to drain. The angle of the engine in the car and casting features in various components will prevent a complete drain.
Posts: 3.6K,
Visits: 497.7K
I replaced my draincocks with the valve shown below. It's a marine item and should be available at a place that sells boat parts-I also find them on ebay.. It also works in the radiator. Because of it's design, you can attach a hose to it to direct the water/coolant. You use a wrench or socket on it. All brass so no rusty butterfly. Also goes under the brand Quicksilver.
