Looking for A Valley Pan with rear Opening for Road Draft Tube
Posted By oldcarmark 7 Years Ago
BamaBob
Supercharged (418 reputation)Supercharged (418 reputation)Supercharged (418 reputation)Supercharged (418 reputation)Supercharged (418 reputation)Supercharged (418 reputation)Supercharged (418 reputation)Supercharged (418 reputation)Supercharged (418 reputation)
Posts: 156, Visits: 11.6K
Miker, are you saying that you just drill a hole in a regular valley pan that doesn't have a baffle and install the grommet? Is there no problem with oil getting in it?
Posts: 1.8K, Visits: 194.2K
I used the previous version of their grommet, looked more like what I’d call a “duck bill” on both a stock bird cover and a finned aluminum cover. Worked fine till I went to the hi volume/pressure oil pump. And the supercharger and cam, and started winging it past 5500 rpm. Then I started to suck oil in. I added a baffle in the aluminum cover, but I’m still using one of those grommets. They’re made to go in a valve cover, but there’s a lot of oil flying around in most of those, too.
On a stock motor, I didn’t have a problem. RPM and boost complicated things.
I got the Grommets. I assume You still need another Grommet to fit the PCV and fit inside this One or will the PCV fit as is?  Mine is just Stock Motor so I think this will work for Me in the Valley Cover.
BamaBob
Carl, do you still have a valley pan with the road draft tube hole in it for sale? Thanks for your reply.
BamaBob
Posts: 1.7K, Visits: 306.2K
Is this what you are after?
PVC Valve Grommet w Baffle - Moroso 68776
http://forums.y-blocksforever.com/uploads/images/f3da9da5-c257-4dd0-87dc-dfe7.jpg
KULTULZ (12/1/2018)
That's the One I purchased. Haven't used it yet as I have my Motor out to re Gasket and new Seals.
miker (10/10/2018)
What Size Hole do I need to cut for this Grommet?
Last Active: 5 hours ago
Posts: 6.1K, Visits: 442.5K
Those are usually designed for a 1 1/4" hole.  However, there can be quite a difference from one grommet to another.  Measure the diameter of the grommet with a caliper, use a hole saw which is about a size under the desired diameter and then use a dremel to fit it to the grommet.  That way you avoid making the hole to big.
If you use a 1 1/4" hole saw, it will be too big because hole saws are not extremely accurate cutting devices and the fact that the grommet may actually be a little smaller could  make matters worse.
carl
Posts: 1.2K, Visits: 20.6K
BamaBob (12/1/2018)
BamaBob
Yes I still have a couple  Carl
charliemccraney (12/1/2018)
Sorry for taking this Topic away from original Posting. Does the PCV fit in this Grommet once installed or am I going to need another smaller Grommet to fit inside this One? I haven't really checked it as I am not installing in yet.
