Starter ID
Posted By paul2748 7 Years Ago
Last Active: 23 minutes ago
Posts: 3.6K, Visits: 497.7K
I have this starter - don't know if for a flathead or a Y Block.  Can any one ID this for me.  If a YBlock, I want to sell it - cheap.  PM or email
me    Thanks
http://forums.y-blocksforever.com/uploads/images/470795f5-a529-4ef0-b9e8-4f59.jpg
Last Active: 4 hours ago
Posts: 3.7K, Visits: 323.0K
Paul, my vote is for flathead.  Y starters have a three bolt flange where it bolts to the bellhousing.  Flathead starters have two through bolts and bolt to a "starter plate" that in turn bolts to the bellhousing.
John - thanks.  Now that you mentioned about the mounting,  it cleared the cobwebs
Gene Purser
Posts: 220, Visits: 6.0K
Not to throw a wrench into things, but an early 60s FE starter has the same case and mounting bolts as a flathead. It has a longer shaft for the bendix, though. A 12V starter for a flathead can be made by using the case of the 12v FE starter and the armature of the 6V flathead starter.
Lou
Last Active: 7 hours ago
Posts: 562, Visits: 8.3K
I have never seen a FE starter that mounted thru the case, on any of my 58/60 birds or my 58 Ford, all were 2 bolt thru a flange. Could this have been a starter used at another assembly plant?
Talkwrench
Posts: 898, Visits: 23.2K
Ive not see a bendix like that one ?
Gene Purser
Lou (10/2/2018)
Lou, Thank you for jogging my memory. I think the two through-bolts on the FE starter bolt into the flanged mounting end plate. The conversion to the flathead starter requires using the flathead front end plate as well as the armature.
