HOOD PROBLEM 55 Tbird
Posted By 55charliebird 7 Years Ago
55charliebird
Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)
Posts: 192, Visits: 39.2K
The broom pushed against the latch bar, popped it open.  Thanks
55charliebird
That was my thought about the broom handle since that the driver side corner did not latch I can reach the hook where the cable attaches. I will "McGiver"  a back up mechanism.
Thanks.
DANIEL TINDER
Posts: 1.7K, Visits: 154.2K
You need to raise the car and access/trip the hood latch from underneath. They sell a special tool for that (Casco), but I understand a cutoff broom handle will work. When you fix/replace the latch cable, you might consider rigging a backup emergency wire/loop, just in case.
6 VOLTS/POS. GRD. NW INDIANA
55charliebird
I inadvertently closed my hood and it latched on the passenger side but not on the driver side corner.  I pulled the hood cable and it  came right out of the housing.  Now you guessed my next question.  HOW DO I GET THE HOOD OPENED.  Fortunately I did not latch the drivers side corner, so I can raise that corner a few inches.   Has someone got any ideas how to get it unlatched (remember, its the passenger side that is latched)...Thanks as always.
