Installing wave washers on 55 T-Bird 3spd shifter rod ends.
Posted By 312YBlock 7 Years Ago
312YBlock
Posts: 217, Visits: 57.3K
I trying to get my 3spd O/D to shift as smooth as it can. The schematic of the shifter arms to trans shows a wave washer installed on the end of the shifter rod where it attaches to the shift lever and also to the transmission lever followed by a 5/16 flat washer and a cotter pin. I’m missing the wave washers and thought this an easy fix until I crawled under the car. I can barely see the rod ends let alone get my hands on them. It looks like I may be able to get at the shifter connections if I remove the muffler on the drivers side. The end that attaches to the transmission is another issue. Can anyone offer any advice?
1955 312 T-Bird Warwick, NY
Vic Correnti
Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)
Posts: 347, Visits: 12.3K
Why not remove the levers on the transmission to do it. You may also remove the transmission mount. You might also pull the shifter out rods and all.
Posts: 1.2K, Visits: 285.6K
To pull out the shifter assembly you will need to pull up the carpet as the shifter is screwed to the floor.  I have the transmission out of my 55 TBird right now.  Removing the transmission cross member should get you some more room.  My car has O/D and the tunnel is very tight.  To remove an O/D transmission without removing the engine in these cars you have to unbolt and drop the bellhousing with the tranny.
