Chassis swap
Posted By 55 GLASS TOP 7 Years Ago
55 GLASS TOP
Posts: 389, Visits: 31.8K
Hello , Anyone know if I can use a club sedan chassis under a Crown Victoria body . Thanks for any reply
Y block guy
Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)
Posts: 42, Visits: 1.4K
The Ford P&A book lists two frames, box type & x type. I think the x frame is t bird. The box type calls out different mounts on Victoria and Sunliner, going by that the frames should be the same for 55'&56 cars
Lou
Posts: 562, Visits: 8.3K
, The short answer is yes, there may be a difference in the body mounts but I don't think so as a crown is just a fancy sedan.. 1952 to 56 Fords share the same frames.(52/53 front suspension is different) X frames were used on convertibles
Dave C
Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)
Posts: 101, Visits: 31.2K
Be advised, there is a VIN stamped on passenger side front frame horn, vicinity of radiator support.
I had read about this so I went out and checked mine while body is on rotisserie, sure enough it's there..
Dave
darrell
Last Active: 4 Months Ago
Posts: 455, Visits: 22.2K
they are different.the hardtops and crowns had a strip welded to the bottom of the frame to stop flexing as well as more body mounts.in 56 they made the frame 1/32 thicker and didnt weld the strip on anymore.a few early 56s still had it.youll have trouble with doors with sedan frame.
