REMOVING OLD FUEL IN THE TANK
Posted By 55charliebird 7 Years Ago
55charliebird
Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)
Posts: 192, Visits: 39.2K
To my surprise I found "liquid" in the gas tank.  Smells like weak gas, yellowish in color.  I was told by previous owner that tank was fairly new and empty.  NOT SO.  My question is removing whatever the liquid is.......what is the best way to remove it w/o removing the tank.  I have a 12V syphon pump.  Once removed I can put vinegar and baking soda in it then insert  air compressor hose into the tank.....release lots of air bubbles to agitate the liquid,  then syphon it again. Thoughts and ideas.
Last Active: 20 minutes ago
Posts: 3.6K, Visits: 497.7K
No drain plug?
This post has been flagged as an answer
Posts: 1.9K, Visits: 194.9K
Remember even old gas will burn or exploded, including the fumes. So I’d be a little careful about using a pump if it’s not explosion proof. Or hand driven and all brass or plastic.
On a bird, there’s a plate,under the mat in the trunk that gives access to the fuel level sender. Pulling that gives decent access to the tank. I don’t remember if that lets you get to the “sock” on the pick up, but someone will know. And it will let you have a look at the residue. If there’s no rust, and just a little varnish, I’d put a couple gallons in and see what dissolved. Might get lucky and just have to watch and change the filter.
Remember, the smoking lamp is out. Even an empty tank with just a slight smell of fuel can go off.
DANIEL TINDER
Posts: 1.7K, Visits: 154.2K
A cheapo bulb-siphon would be simpler (forget the ‘old school’ mouth-siphon routine...if you swallow/inhale old gas, you will learn the meaning of ‘severe distress’).
6 VOLTS/POS. GRD. NW INDIANA
Daniel.  I had to laugh.  Your terminology is 100% correct, but my mom always called it a turkey baster!  Smile  Thanks for bringing up that memory.  It's a GooD suggestion of a way to do it, too!
DANIEL TINDER
Actually, a ‘turkey baster’ would not have a one-way valve like a bulb siphon/tubing kit. Also, it occurred that (depending on how much liquid is still in the tank), it might be worth the cost to partially fill the tank with gas before siphoning it back out, in order to delute the old residue, since the siphon process might work/start better, and a siphon never removes as much as pulling the drain plug would. You could always use all the recovered/contaminated gas in something less sensitive/valuable (lawnmower, rental car, brush-burning/weed-killing, etc.)?
Cliff
Last Active: 7 hours ago
Posts: 878, Visits: 13.5K
Don't those Birds have a drain plug?
I mentioned a drain plug before.  I don't understand why people are discussing other ways.
Most 50's Fords, if not all, had drain plugs.
Cliff (8/3/2018)
slumlord444
Posts: 1.2K, Visits: 137.8K
Never seen anything with a Y block in it that didn't have a drain plug but I'm not familiar with trucks.
Lou
Posts: 562, Visits: 8.3K
None of my 55 or 56 Fords had drain plugs (Marwar & Summerville) from the factory, all were early production, before 2/56 , could the drain in the tank have been added later in production?
