Radiator
Posted By 55charliebird 7 Years Ago
55charliebird
Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)
Posts: 192, Visits: 39.2K
What is the capacity of the 55 Tbird radiator.  Radiator only.  Getting ready to refill system.  Thanks.
Last Active: 25 minutes ago
Posts: 3.6K, Visits: 497.7K
I just  fill it up to a little over the top of the core with 50/50 water/antifreeze.
Last Active: 4 hours ago
Posts: 4.6K, Visits: 38.4K
Please don't fall for the premix 50/50 deal. You pay as much or more for 1/2 water. If you want to be sure premix in a bucket at 50/50 and save the money.
57RancheroJim
Posts: 729, Visits: 112.0K
Use distilled water if you mix your own, let it go through a few heat cycles to get all the air pockets out and refill as needed. Leave it about an inch from the top of the tank for expansion.
55charliebird
It took 1 gal. of concentrate and 1 gal.  of distilled water.
I agree 100%  mix your own.
MoonShadow (7/27/2018)
cokefirst
Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)
Posts: 152, Visits: 2.4K
Unless you are in an area where you need the cold weather protection from freezing, I would suggest a 1/3 long life coolant and 2/3 distilled water.  The engines in many of these cars tend to run warm.  the 1/3 coolant is enough to inhibit rust while the higher concentration of water will dissipate heat better.  Water transfers heat to the radiator better than coolant.  Just my humble opinion.
