Visits: 285.6K
I have used Red's Y Block Headers in the past in a 1957 Ford Passenger car. They're not fancy, but they work. Anyone tried them in a 1955 Thunderbird with a manual transmission? What are other alternatives to stock exhaust manifolds.
Visits: 22.4K
FPA. Best header for torque and horsepower out there short of custom. Ceramic coated and fit snug to engine. I recently tried to get a set of headers made for my '55 Thunderbird, and the so called "header guru" quoted me a price of $3500.00 and I would have to take the car to Charlotte for the fitting. My FPAs made the best score on a dyno test recently among five different brands. Joe-JDC.
Last Active: 48 minutes ago
Visits: 442.8K
In Ted's testing, the FPA headers were right at the top and are the best headers you can buy off-the-shelf for a Y, period. Too bad they only fit T-Birds. http://forums.y-blocksforever.com/FindPost99070.aspx
Last Active: 2 Weeks Ago
Posts: 1.9K,
Visits: 194.9K
I’ve run both sets on my 55 bird, manual trans. The Red’s aren’t a true “Tri-Y”, as the primary tubes aren’t paired to the firing order. There’s a pipe available that goes from the exit and snakes down the the original exhaust system. Kind of an S bend. It’s 1 1/2” or so, and mates to the stock muffler. They looked good, fit well, and held up fine. But they don’t buy you a lot of power due to the size restriction.
The FPA’s are just what Ted’s results showed. They also fit well, but they’ve got a bigger collector. The ones on the car now have a 2 1/4” exhaust, exiting behind the rear wheel. My car has a tri-4 bar with coil overs in back, otherwise I would have gone 2 1/2”.
Based only on the seat of my pants, I’d say there’s not much difference with a stock motor and full exhaust system. You start adding ported head, more cam, at one point I ran an SN series supercharger, the FPA’s start to post the gains. Currently, the car runs a 10.5 to 1 compression and aluminum heads. No doubt in my mind the FPA’s are needed with those mods.
Visits: 285.6K
Thanks for the replies. When I pulled the motor out of my 55 TBird, I found two different types of exhaust manifolds. One side was the original 55 and the other was from an early sixties Y block of some kind. I would like to find two 1957 TBird exhaust manifolds which I assume are rare and pricey. I ran a set of FPA headers in a 1957 Ford a few years back and I liked the quality. I am not a serious racer. My car has 57 heads, intake and valve train. I am building a new motor with an Isky E4 cam. I am looking for options.
Visits: 8.3K
Right side exhaust manifold is same as passenger car, left side is T-Bird only
Visits: 33.3K
Sanderson also makes a set of headers for the T-Bird (FTB1:$575.00 coated) although not as good as the FPA's.
Posts: 3.6K,
Visits: 497.7K
This guy may have a set of 57 manifolds for a Tbird Adrian, lilbirds567@wmconnect.com. No idea what he would want for them Florida_Phil (7/8/2018)
Visits: 285.6K
I emailed Adrian and he has a 1957 Thunderbird driver side exhaust manifold he will sell me for $175. In the photo he sent me the middle casting number is "9429" and the bolts are broken off in the exhaust flange. Isn't the right casting number for a 1957 Thunderbird Exhaust manifold ECJ-9431-C?
Posts: 1.4K,
Visits: 179.6K
Phil. I checked with a friend who has been into 'Birds forever. In checking his parts, he has an ECJ 9431-C exhaust manifold tagged as being off a '57 Bird driver's side. He also has an ECJ 9431-A exhaust manifold tagged as being off a '56 Bird driver's side. Other than the casting number, I don't know the difference in the castings. IF you can reference Gil Baumgartner's authored Classic Thunderbird Club International Thunderbird Restoration Manual, you will likely be able to obtain more info. I don't have access to the book at this writing.  Hope this helps.
