Visits: 3.5K
My friend replaced the two hoses between the control valve and cylinder on his 1957 Fairlane and he can"t get them to stop leaking, Any Ideas would help Thank You
Visits: 8.3K
Teflon tape
Visits: 32.6K
If its leaking at the Control Valve end its possible the Seats in the valve are damaged. They are replaceable but probably best done by a Company like Lares.
Visits: 190.0K
same issue ,found some hoses 2 short,as well be sure to use proper brake line wrench.my hoses where from mack. i eventually went to hyd shop had 2 made.(57 ranchero)
Visits: 3.5K
will go see my buddy and see just what is going on tried tape it didn't help Thank you for suggestion
Visits: 8.3K
Maybe the connectors on the new hoses are metric ?
