Bendix in or bendix out.
Posted By 55charliebird 8 Years Ago
57RancheroJim
Posts: 729, Visits: 112.0K
I've heard of people flipping the gear but I decided not to try it and just bought a new one, they aren't expensive I think mine was $20. The ring gear also has a small bevel on the inside that goes against the flywheel.
I’ve flipped the starter ring gears on standard trans flywheels without issue but if a new ring gear is available and time is not an issue, then by all means purchase a new ring gear.  If flipping the ring gear on a V8 flywheel, then be sure to clock it 45° different than where it was originally so that the new side being used is contacting a fresh set of teeth.  You’ll find starter wear marks each 90° on a V8 ring gear and 60° on a six cylinder and you’ll want the reversed ring gear using a unused section of teeth.
55charliebird
Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)
Posts: 192, Visits: 39.2K
Installed the heavy gage battery cables today (made by NAPA).   The engine turned right over (with the original starter) in it.  So now I have the brand new starter that I will keep,  just in case.  Cable size was the fix.  When I started to dress up the engine compartment, I started replacing battery cables.  They were lighter gage......no good.   Thanks for all the help and ideas
55charliebird
The new NAPA ground (red) cable worked. Now I need  to find out why there is no spark from the coil.  I;m sure it is a bad grounding of the distributor.
Tedster
Posts: 513, Visits: 153.3K
Have you tried a known good condenser? As mentioned in the other thread the new ones, are not specifically too good.
