Wheel hopp problem
Posted By slumlord444 7 Years Ago
slumlord444
Posts: 1.2K, Visits: 137.8K
Finaly got enough miles on the new engine to push it a bit. Geting wheel hop on a hard launch from a dead stop. About 3500 rpm or so and let it fly. Running a top loader 4 speed, 3.89 Traction lock rear end. Radial tires. New rear shocks. Station wagon rear springs. Original traction masters with new bushings and the front mount bolted to the side of the front spring hanger. Ran home made traction masters with front mount welded to the frame back in the '60's with no problem. Ran bolt on slapper bars later with no problem. Trying to figure out why I'm having this problem now. Same rear springs I had back then. Any possibility the traction loc rear end is doing something funny that I am thinking is wheel hop? Seemed like It was leaving a back strip on the road on the left side but not the right side whch makes me question the tracion loc. Have the right lube and aditive in it.
Not an expert in this area, but assuming the traction loc is working, it may be torque lift of the right side wheel?..
Sandbird
Posts: 131, Visits: 542.7K
Does sound strange no black marks on the right since the right has the tendency to lift when you make a hard launch. Maybe a broken axle or a spider gear from the violent take offs??
Posts: 1.8K, Visits: 306.3K
slumlord444 (5/16/2018)
Can you have someone watch a launch to see of the right tire is lifting (or better yet video)? Are the leaf springs new or take-offs. Eye bushings good? Are they clamped?
I would think you would want to anchor the TM to the frame rather than the front bushing hanger.
Extra leaf on right spring...pinion snubber...50/50 shocks?
What car and engine?
Regarding the wheel hop, the rear suspension springs are weak and you’re simply experiencing ‘spring wrap up’.  Clamping the springs is a viable short term fix.  Something appears to be amiss with your traction bars as those should be eliminating the wheel hop you’re experiencing.  I’ve added additional leafs to my car to compensate for sagging springs and that restored both the back end height and eliminated the wheel hop.  I have had the rear springs re-arched in the past but it seems the springs have a memory of where they were and the re-arching simply doesn’t last long.
If you didn’t pull the traction lock apart and examine the clutches, then you may simply have a worn posi-unit that’s not holding the power.  Besides the wear that occurs to the fiber posi clutches over time, the clutch material itself is known to break down and deteriorate over time.   A disassembly of the unit and a thorough examination will determine if it needs a rebuild or not.  If the unit had been rebuilt before using it, then I'll suggest shimming the clutches so that they are tighter.  Not all traction locks are created equal either.  The later model four pinion units would appear to be more robust than the earlier units.
Lou
Posts: 562, Visits: 8.3K
If wheel hop is the problem, then any tire marks on the ground would look like dashes not a single black line.
DANIEL TINDER
Last Active: 7 days ago
Posts: 1.7K, Visits: 154.2K
Installing new shocks with integrated coil springs was a lot simpler than re-arching/replacing my leaf springs. Brought the ride height back to stock....couldn’t be happier. But, too worried re: u-joint damage to test for wheelhop.
6 VOLTS/POS. GRD. NW INDIANA
slumlord444
Car is '57 T-Bird. Shocks are new KYB gas. Springs are from a '57 Ford station wagon which have one more leaf than the T Bird. I put them on the car in 1965 or 66 after breaking a spring. Pulled them off a car in the junkyard at that time. No broken leaves and don't apear to be saging. Ride height is within spec's. Traction lock was just built with a 2 pinion carrier and all new gears, bearings, and traction lock. Only has a few hundred miles on it. Front traction master bolted to the spring bracket should work the same if the bracket was welded to the frame. No way it can move. Only did two hard launches with it since I got it on the road and that was after some break in miles. Spring bushings are fine. Installed the traction masters with the car setting on the floor per thier instructions. Nevefr had a problem before with the same springs and home made traction bars and cheap bolt on slapper bars later on. Used to lauch it on the strip at 5500 rpm with cheater slicks and 3.89 open rear end. No wheel hop and most competitors had to try to catch me.
Vic Correnti
Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)
Posts: 347, Visits: 12.3K
I don't know if the 57's are like the 55's but I had to relocate my shocks vertical because they were at such an angle. The 55's have a narrower spring and I had Eaton spring make me a stock set and then a beefed up set, clamped them, added Caltrac's but the relocation with double adjustable shocks is what seems to have fixed it for me.
slumlord444
Since the only real change made to the rear end was the Traction lock I am still thinking the problem could be it. Any easy way to check it out to make sure it is working right without doing damage if there is a problem with it? All new parts in it and had it built by a friend who is a professional mechanic I have know forever. There was a problem with the first ring and pinion in it and the gears self distructed in a few miles. No gear noise in it so far. Put some miles on it before trying a hard launch per the instructions that came with the parts.
