                Visits: 1.6K
                As you see I’m not too computer savey! That said I put a new valley plate on my 292 it has no oil fill in it. I put the fill in the valve cover it has breather holes , l now have a little oil coming out of the draft tube on the left side of the engine? I removed the tube and blocked the hole . If I put another breather in the other valve cover will the engine breath enough so I don,t get seal leaks in other places?
                Visits: 32.6K
                Do You have a PCV System installed?  You need either the Draft Tube or a PCV System to circulate internal Air in the Engine. Blocking the Draft Tube opening with no PCV will pressurize the Engine causing Leaks. The Oil Fill Cap allows filtered Air to be drawn into the Engine. It needs somewhere to exit the Engine.
                Visits: 1.6K
                Ya I thought of a Pcv can I put one on an older engine mine is a 57 ? Where can I tap into the intake ?
                Visits: 442.8K
                You want the pcv port to be located as centrally as possible.  As close the the carburetor as possible with even distribution between the two planes of the intake.  Modern carbs usually have a port designed for this.  Alternatively, a carb spacer may be the best choice. Here's a link to a recent discussion: http://forums.y-blocksforever.com/Topic135492.aspxMore can be found by going to Explore then scrolling down to select search and search for PCV.
                Posts: 1.4K,
                Visits: 179.6K
                Paul M. I'd recommend that you consider changing valley pans.  Click the link below to see the valley pan that is usually used for hooking up a P.V.C. unit on a Ford y-block. Click the link below to see a current valley pan listing on eBay https://www.ebay.com/itm/60-61-62-63-64-FORD-272-292-312-Y-BLOCK-ENGINE-INTAKE-VALLEY-PAN/132577902670?hash=item1ede42404e:g:jlsAAOSwPqRazhqM&vxp=mtrI suspect that you presently have a valley pan like the one listed below.  Click the link to see this eBay listing. https://www.ebay.com/itm/MOON-FINNED-VALLEY-COVER-Y-BLOCK-FORD-MERCURY-V8-RAT-HOT-ROD-CUSTOM-VTG-STYLE/392020009652?hash=item5b4636a2b4:g:-B4AAOSwnHda0ojb&vxp=mtrI've seen marine application y-blocks that used an oil fill opening on one of the valve covers. Hope this helps.
                Visits: 32.6K
                The Draft Tube drain back may  be plugged up. This is supposed to allow oil from the Filter inside the Can to drain back into Engine. I would also suggest You re-install the Road Draft Tube until You figure out what You are going to do. With no ventilation inside the Engine gas Fumes also build up. keep driving it with no Ventilation and the Engine just may go "Boom" because of the Gas Fume buildup..
                Visits: 1.6K
                Thanks all u guys ! I picked up a Pcv valve at the store it seems the best place for me to put it without taking everything apart is the valve cover. I have a breather on the other valve cover and my Holley has a port to plug the tube into I hope this works really don,t want to put that draft tube back on .
                Visits: 32.6K
                You may have to experiment to get a PCV  that works not allowing too much Vacuum at Idle. You can try restricting the Hose and see what works best.
                Posts: 1.4K,
                Visits: 179.6K
                Oldcarmark is offering good advice.  O.E.M. P.C.V.valves are application specific except for engines that have had engine modifications like over-bored cylinders, significantly milled cylinder heads, or aftermarket camshafts installed with modified valve lift, valve timing, or valve opening duration.  The appropriate P.C.V. valve opening size and check-valve spring tension will assure the component's appropriate opening and closing operation for your engine which will prevent excessive crankcase pressure build-up and / or poor engine idle.
  The auto parts store you turn to should have application information for early '60s FoMoco y-blocks that came equipped with O.E.M. P.C.V. valves.
                Visits: 32.6K
                When I did mine I used a PCV for mid 60's 289 Ford. Too much Vacuum at Idle. I ended up using a PCV from early 80's Fairmont / Zephyr 4 Cylinder. Could probably do better Yet. Just haven't tested further. There's an adjustable Aftermarket  PCV available now but Pricey.
